so, I see that there has been a software update on June 1st can we possibly get a changelog? @langmuir-jake
quick thing i have found with the laser-control software update:
cam is enabled, you can direct import vector and dxfs and do programing on machine
material parameters are attached to this adding kerf per formula to do adjustments and automatically exporting speed and feeds to gcode
post can be exported to a drive or on computer for further use or sent directly to the control side
multiple firmware updates for the controller and sub controllers don’t know what those changes were, home for x and z are still disable unless i missed a step.
table orientation match to jog has been added its in the gear wheel with 3 tabs
Home x, xy, xyz has been added. DO NOT USE THIS WITH OUT CHECKING WHICH WAY X IS GOING! on mine its going the wrong way idk if this is on my part or if its broken.
chill alarm has been added; it doesn’t work for me just keeps sending alarms until I turned it off in settings LCB tab.
rapids speed limits can be changed in the settings now; acceleration can be changed also.
editing material properties and saving breaks for me after saving and loading a few times, load blinks but cannot be pressed, and have to exit and reload the software.
