hello im attempting to make a fire pit for my famil mainly that my wife wants for my deceased mother in law as a tribute. I made the files on fusion already. problem is my table is not big enough. I dont want to make it smaller because i think it will not be a big enough pit for files. Just putting it out there if anyone would cut these for me and i will pay. I will even send the metal. I work at a weld shop and have been trying to get the files on our cnc plasma table but no matter what file i put it under they cant read it. its roughly 15x30 i was gonna use eighth inch steel. thanks for reading
Just index the cut.
Make two separate cut files, use something square to create a fence/jig, and move the steel sheet upwards for the second cut.
where are you?
have you checked Send Cut Send? They are very reasonable and most times it free shipping
pennsylvania. i looked up send cut send. ill look into them more. thank you
Where in pennsylvania and how big is part.
by pittsburgh. its 4 pieces 30 in x15 in roughly
Ok sorry i am in nepa poconos. Not close by.
You’ve waited for a week - is there a reason why you don’t want to index?
Being a firepit makes the item much less critical, as really the only challenging part is ensuring your steel is square on the table.
Set up a guide/fence/jig to feed the table perfectly vertical for your second cut.
thanks again. it worked perfectly. got them cut and they came out great.
Well everyone loves a good project, should post your projects!
