I tried a few flap discs with a similar label. I wasn’t impressed .I have found I can pay 12 bucks for a flap disk and get way more service out of them.
As for grinding rock I like the tiger brand fairly well. flap discs I have been buying norton red heats. Some times the labels wear off. I have a variable speed grind I usually turn the rims down on flappers.
I use the benchmark flap discs a lot. I have them in 40 and 80 grit flat and taper. Seem to get good wear out of them for the cost. Yes the labels come off but I mark them with a sharpie or paint pen so I know what they are.
I reached out to Benchmark awhile back, Jack said he had not had any other compalints about the disks not being flat and he would dig into it. That was several months ago. I sent another Email again and will see what happens. I do seem to get a Email every few days about some new sticker or something
What is the cost for a grind rock? I think the tiger brand we get from Fastenal is around 4 bucks each maybe. I just looked for a old invoice I don’t have one.
I usually use a 9 inch grinder for flat grinding. Most of our 4 inch grind work is for either crack removal or weld prep. Those flap discs I tried was useless for my needs seems they couldn’t be laid flat to polish a flat surface. It’s like they” negative rake” on them. At work we use them to polish a surface that isn’t critical but looks a lot better when polished.
I am confused you don’t know what a grinding rock is? well I should have said disc. We call them rocks here. That’s what was the first picture you posted….
I didn’t notice auto correct took the ing off when I posted.
It’s not you. It’s a disconnect between regions I would say.
I was curious what you are paying for the grinding discs. Them being out of balance as bad as you say they could explode or break apart. That could ruin ones day in a hurry.
yea, labels always fly off on the ones I’ve got. I always mark the grit / material (if dedicated for SS, for example) on the top side with a silver sharpie.
I can see why they are so cheap .. Be careful a unbalanced disc in the right condition can be dangerous. They are considered a no no at work when they become chipped or severely unbalanced.
I use there flap discs and carbide burrs, but I have never used there grinding discs. Have you contacted the company? They seem like a good company, I bet they would replace the discs that are unbalanced. I don’t recall ever having a label come off but I use battery operated grinder for the most part so it is not turning at break neck speeds.
