Anyone uses XR for aluminum cutting?
I 90 percent work with 1/8-3/16 aluminum and was wondering if the xr would be upto the task. I understand slight cleanup will be required . thx
The table has nothing to do with it.
Your plasma cutter, dialing in your settings, and the quality of your air will dictate your results.
@Bigdaddy2166 cuts quite a bit of aluminum with excellent results on an Everlast plasma cutter.
Yes the XR paired with a good quality plasma cutter will cut aluminum well.
You’ll have to watch out for the nozzle getting fouled more often than steel and it makes a huge difference with aluminum.
We built several of these benches with art panels out of quarter inch aluminum last year and have built a few more this year and they turned out.
Cutting aluminum can be fickle though so keep an eye on the nozzle and cut height and make sure you do some test cuts ahead of time.
thank you, Thats the kind of info im interested in, and already own everlast welders :slight_smile:
thank you. Which plasma are you using ? work looks great!
Thank you . For these cuts I used my Hypertherm PowerMax 85. I use the 45 amp consumables and settings from the manual. With a 50% slow down for corners and radii.
I use on aluminum from time to time. No big issues. Bit of a burr to deal with and the actual edge on 1/4” is pretty gritty. Not as noticeable on 1/8”. I recently got a stroke sander for a job and it rips right through that burr.
That cut is very good. Unless you use nitrogen instead of air, the edges will oxidize.
