Anyone in here use bendtech sm. I used to use pro for my tube work long time ago and wanted to see if anyone was using sm on there table. I do not want to learn fusion and am looking at alternatives.
did you ever find anything out ? i just found your post through the search bar. because i use bend tech religiously on my tube work. its been an amazing program. i am wondering the same thing. can i use the sheet metal module and lay it out flat it bend tech and create cut paths ?
Yes, you can cut flat layouts in sheet metal module. I use sheet Cam to create the tap file, works great.
