Been working on Fusion 360 on my MAC this past week more than usual but am noticing it’s crashing almost every time I’m using it. Asked a friend that is using it also and he’s noticing the same thing. I tried to uninstall and reinstall still no luck. Was about to wipe my MacBook and reinstall the OS but also noticed it doing it on my other Mac mini. Just wanted to see if anyone else is having issues like this. Anyways I did get a few things cut this morning.
Good morning. I don’t use MAC but thought it would be helpful to note I have not been experiencing any crashing in Fusion 360 on either my desktop or laptop running on Windows 10.
Nice work by the way! I just got mine setup and playing around with 16ga steel but getting a lot of dross on my cuts. Would you mind sharing what height, speed and amps you are running? Thanks in advance.
I’m talked with auto desk they are looking into it I’m thinking it’s related to some file that l created from an SVG it’s only doing it with that one file.
Yes this was done on 16ga with a Hypertherm 45xp it says I can do 250ipm but had an issue on one where it didn’t cut through thinking it was a bad ground but I was worried so bumped it down to 190ipm all set at .062” and 45amps wth the fine cut tips
I have been running Fusion 360 native on my MacBook Pro. I have not had any issues running Fusion 360 native on my MacBook Pro. I have been using Virtualbox running Windows 7 to run Mach 3. I have not had any issues running Mach 3 using Virtualbox on my MacBook Pro either.
