I’m making a plate for a CNC Router and used Tracer to create an SVG of it. I imported that into Fusion and, after looking at it, decided that it might be better just drawing my own using the SVG as a guide.
Ok, I did that, but now find that the imported SVG is useless and I want to delete it. However, I made the mistake of drawing in the same sketch as the imported vectors and I now have to go through and manually delete every little vector because I can’t figure out how to isolate those vectors from the drawn ones.
Obviously putting the import in a separate sketch would have avoided this, but is there any trick to isolate the vectors now?
