While waiting for the Plasma cutter I decided to add an aftercooler to my air compressor. I’ve only tested it once but no leaks and it seems to remove quite a bit of moisture. On the first run from start to cutoff there was a 113.5 degree F delta. I did not measure the output of the autodrain filter but I’d esitmate it at 2.5 oz.
