Does anyone know what machine torch is compatible with the Andeli cut 65 DS?
We just ordered our new Crossfire XL and want to find the machine torch so I’m ready when our table gets here. Thank you.
I really don’t want to sound like an ASS here.
But why do you people buy the cheapest Chinese plasma cutters for your CNC table? Do you like the idea of trouble shooting all the time, getting bad cuts, using cheap Chinese consumables that most of the time don’t last more them a few minutes because they are really not the right ones. Or just like the challenge of seeing if you can make it work.
I know I am going to get push back on this but it is something I really would like to know the answer to.
Now on to your question on a machine torch.
What ever machine torch you get it will most likely have to be rewired for your plasma cutter. Now as far as a machine torch a IPTM60 will work but your limited to 60 amps, but can get cutting tips in 20, 30, 40, 50 and 60 amps to do most cutting you will need.. A IPTM80 then you limited to 40, 50, 60 and 70 amp cutting tips to get the full 65 amps they say it will put out. Now there is the X45 style torch but there again your limited to 30, 45 and 70 amp tips.
No push back from the peanut gallery. 100% correct. I liken it to a 69 Z28 with a 250 6 cylinder in it.
But George, you do such a great job at it!
