Hello, I am waiting for my Primeweld CUT-60 plasma cutter to arrive and I want to ask you if this air compressor is good enough to buy it. Thanks in advance.
It will work as long as your not using it on a CNC table or making long cuts on 1/4" or more metal.
Thank you!! I bought this cutter precisely for use in a Crossfire CNC table. What specifications should I look for? Again, thank you very much for your help.
You will need at least a 30 gallon tank 60 would be better and will put out at least 6cfm of air at 90 psi the more cfm the better for a cnc table
Thanks again George. I found this one, what do you think?
http://www.powermate.com/air_compressors/product_detail.php?model=PLA3706056
Yep, that’s what you need to run a small shop and a CNC table
Quick scan and didn’t see a price in that ad. But Lowe’s carry’s 60 gallon 2 stage compressors for roughly $550
Thanks again George. Have a nice day.
Thanks cmalooski1 ill check it.
I would also look at HD and Lowes locally vs online as I found my 60 Gallon Husky on discount for some reason but it saved me some money, just a recommendation.
You may even get a better price if you sign up for a Lows or Home Depot card.
