Is anyone using adobe illustrator to design and is it easy to transfer into firecontrol?
@Skookum uses illustrator I believe.
I think @jamesdhatch does too.
You’ll need SheetCam to provide the CAM functions and post process into code that FireControl uses.
I go from Illustrator to Fusion360, to FireControl.
I’ve had issues with incorrect sizing if I go out of AI via SVG. But it does fine via DXF.
If you work with existing graphics or have experience already in AI it’s a good tool.
However, as I’m learning, it does make sense to get to know Fusion360 for many other reasons, especially if you need a quick edit. I’m not designing in it yet but it’s pretty obviously an important skill.
Is sheetcam easy to use?
@Keithc … Keith, Sheetcam is SUPER easy to use!!! Well worth the investment IMHO…!
Are you saving it with the “preserve presentation” setting enabled? Click that off if you do.
Actually, I think I did. Thanks!
