I am using fire control Can I add a code snip in sheet cam between layers M06 To pause so I can make amp adjustment on plasma cutter
If all you’re doing is adjusting the Plasma Cutter setting, then M1 or M0 will work.
Thanks I appreciate it
i tried that a while back… didn’t work with firecontrol. ir errored out.
What didn’t work? M0, M1, M6 or all of the above? Surely M0 must work!
i don’t think i tried M0… i know M6 and M1 didn’t work.
I put in M1 and that worked
It paused the program until I hit resume
Thanks I appreciate the help
can you take a pick of you snippet code in sheetcam? I’ve tried it a while back but firecontrol gave me an error.
Hey I was wrong my code snip is M0 not M1
