A Issue with machine
I was in the process of making baseplates and I had a couple made, I moved on to another size which uses the same tool and setup just a different sized plate, and now my table will move to make the first cut, pierce the material and then not move a inch all while still burning the same whole it started, any idea why this happened or how to fix it?
14x30 plate july 31.nc (462 Bytes)
Does it do the same thing if you do a dry run? What cutter are you using?
Nope it runs like it’s supposed to on a dry run, powermax 85 with a 85A tip, part #428934.
To me it sounds like EMI or a ground loop issue.
Take a picture of your setup. All your cables, work lead, control cable etc.
Are you running fire control on a laptop? Is it plugged in while cutting?
Have you performed the THC test?
Have you tested the USB for continuity to the table? (see below)
