'6-in-1' Easy Backgauge Calibration Procedure
To help with the backgauge calibration for everyone working with their machine, I’ve put together a quick backgauge calibration procedure that should set you up with everything you need with one quick input.
The 6-in-1 procedure sets up all 6 Titan25T backgauge setting slots with useful calibrations using a single reference measurement. The procedure uses the known dimensions of Langmuir Punches and Dies to input values directly into the position of the digital readout.
The full procedure and entry values can be found in the pdf attached.
‘6-in-1’ Backgauge Calibration.pdf (2.4 MB)
