It has been working good up until this cut. I started a cut and got a 300v error. I got several of them back to back. If I let my post flow air shut off it will cut and then give error. I have a everlast 62I hooked up raw voltage. Have 76 PSI when torch is on. I replaced solenoid and still getting the error. I can turn THC off and it will cut just fine. Have clamp clamped on material. I did the trouble shoot guide and narrowed it down to THC chip or MCB. Under flag 4 on guide. I am not getting any resistance between shell of USB and slat bed with ground clamped on. This is where I am struggling with. I can not seem to determine which is bad.
This usually means the electrode is stuck or something is preventing the electrode from blowing back to start the arc (low air pressure).
Forget about the THC and MCB for now. This is most likely a torch issue. Unplug the torch on/off cable from the control box and jump the outside of the connector to the inside with a wire. That should fire the torch independent from the electronics enclosure. If the torch still doesn’t fire, it’s the torch or the plasma cutter.
I used some silicone pray lube that Plasma George recommended me in the past to lube the plunger part on the torch head. Also put new consumables in it also.
Do you have it hooked up raw through the CPC Port of the plasma cutter or hooked up raw by actually running wires into the unit and correcting it directly to the terminals?
THC module ( voltage input module) could be cooked.
You can only get a 300 volt reading when the positive and negative make contact/short when the torch fires. Once their is a gap between the torch and the metal say .060” then the voltage will read 96 to 125 or something along those lines. Make sure your torch height is set correctly.
I was getting a 300V error at start of every cut. If I let the post flow air stop then I could restart it until next cut. I believe what Mechanic 416 said worked. I checked my gap on torch tip and it wasn’t at .063. I raised torch to get that gap and it cut just fine.
