I have a few different sequences of cuts that I would like to do in a program. I have always selected them in order, and created a new cut profile for each…then they cut in order. So what if I have my program made, then want to go back and add a new cut profile that needs to be cut before another one??? Am I able to arrange cut profiles manually, in sequential cutting order? Default always puts the new one last.
In the manufacturing space, you are able to click and drag cut profiles to reorder them. If for example, you have already made Profile 1, 2 & 3, by default Fusion will make Profile 4 as the last item. Select and drag to the spot you want the new profile. (Look for the blue underline.) As long as you post from setup, it will process them in the order you have placed them.
Thank you, got it… that worked and will save me a ton of time!
