My pro is in my garage. Do I have to unhook control box and bring in house during freezing temps? What do other owners do? I can look into putting small heater in garage. Just looking for experience in this area.
If you get below freezing then you need to heat the garage or not use the table. You will need to drain all water from your air system as well as the table.
Frozen air lines and a frozen water table is not a good thing.
I wondered too will it hurt the control box with the electronics ?? But I might be able to answer that your car doesnt need to be inside and it has electronics on it ???
One thing to watch for if your table will go through temperature swings would be condensation. Short term it may not be a big deal, but eventually it could start causing corrosion issues.
