Hello all, as the title says I just bought what I believe is a first gen crossfire. I am 100% newbie, I have a cheap plasma cutter that I use for projects, but I really want to invest in something good to use with this system. I’m in college right now and doing my clinicals, and I would really love to invest in something that I could do a little business on the side making keychains or plaques and stuff like that to sell.
The guy I bought it from recommended a hypertherm, he said that on the forums it seemed like they had the least problems synching up with the software and stuff like that. If that is correct let me know, or if there’s other really good options I’d like to hear those too. As stated I am a college student, so I’m not trying to spend the most as possible, but I’m definitely willing to drop some coin on what I consider an investment.
I really don’t know everything about this and I have not even set up the table, but here is some info I got from the seller. I will paste below exactly what he put in the ad.
"Langmuir crossfire cnc plasm…
XL extension kit. I did perform a modification at this point which is referred to as a “rail swap" of the x/y axis in combination with use of the xl kit, this results in additional cut capacity over the stand or xl configuration.
Current actual cut capacity
X: 30"
Y: 33.3"
Z: The auto height control 0-4"
The thickness or wall cut capacity is determined by your plasma cutter and mechanized cut speed charts in your owner’s manual.
This also has a pair of custom billet machine
torch holders I had made. This allows the use of a
machine torch or hand cutting torch.
Bonus items included in this deal is the water tank, pump & drainage plumbing/valves. I will also included the pivoting laptop stand (made on this very table). The table also has a lower shelf added which is both convenient and gives increased structural integrity. The table sits on height adjustable locking casters and is very easy to move around.
You will need a plasma cutter and laptop or pc. Software is free to download on the manufactures website.
I’m am only selling because I upgraded to a full size table after experiencing nothing but satisfaction with this table."
If I need to provide more information please let me know, I don’t even know what else put on here.
(It will be an easy item to sell if you ever want to get out.) Beyond that, just learn and go make some money. As you make money, then invest back into as needed. You may eventually find you will want a larger table, more powerful cutter, etc. It seems as if the metal sign market has cooled off some. People that are really good and put them time in are still pumping them out…but the people that do it on the side seem to be selling less than in the past. (I guess a lot of people have jumped into the field!)
