1/4” steel plate
I’m about to cut 1/4” hot rolled with my razorcut45. I take good notes but seem to be missing my note from the last time I cut 1/4”. What settings is everyone using? So far I’ve programmed 25ipm, 40amps, pierce higher of .15, cut height of .125
Cut height. 062 not .125… 75 psi while cutting.
Use this chart
I have a RW45 and cut 1/4" at 48 IPM at 45 A .15 P .060 CH.
I do have a Hypertherm torch but that will get you very close
That’s what I had programmed based on my experience, good to know I’m on the right track, I’ll do a couple of test cuts tomorrow
This has been useful for ballpark, although conservative, cut settings.
