I purchased a set of the machine torch mounts from Steve Abner for my Powermax XP 45 Duramax torch. Previously, I was using the Langmuir clamp to hold my machine torch. I had two concerns with this method of attachment. First, I was clamping the torch around the retaining cap. It is my intention to move to a fine cut shielded set of consumables which uses an ohmic retaining cap. The Langmuir clamp didn’t fit this well. I also had a concern that clamping around the retaining cap may interfere with cooling.
Second, I didn’t care for the long moment arm created by using a single clamp at the base of an expensive torch. Steve’s sytem utilizes two clamps which I believe secure the torch better. It is a nice product.
Hey Gene! Thank you for the kind words sir. Look forward to seeing what you create on your table.
Steve.
If you are referring to Steve’s machine torch clamps, yes. They are not needed unless you have a system with z-axis (height) control. The gear removes simply by removing the 2 screws.
@genealto sweeet, I bought Steves mounts over the weekend and I have exactly the same torch you do. I was concerned about that rail on the side.
