Hey guys, so I’ve been having issues with scaling items. Let’s say I get an image, change it from svg to dxf and open it in fusion.
I them try to scale it down from whatever size it is to the size I want, but when I go to modify then scale then select the entire image it doesn’t open up the ratio box to submit what ratio you want to change it. Even if I select the entire image prior to going into modify and scale or make sure the uniform box is clicked it does the same thing and won’t have a ratio box open. I was able to get it working a couple times but I really don’t know what I did different than before.
Any ideas?
