Razorweld Cut Chart
I think you mean 75 psi. You can just add a regulator to the rear and adjust the pressure as needed.
3/16" (7ga) @ 40ipm and 37Amps. Very little dross. Pierce Delay (P2) in G-code… Is that 2 seconds? Razorweld 45 - .06 Shim. 1mm Shielded tip from [mechanic416] on ebay.
Thanks guys, the pleasure is all mine.
70 ipm was the winner although all were pretty good!
70 ipm was good speed with no dross to speak of & a kerf width of .040”
.120” cold rolled steel
.070 TH
.8mm nozzle
35 A
1.0 sec PD
70 psi on RW45cut Gauge
Dry dry dry air!
A 0.8mm tip/nozzle is only rated at 30 amps max. They are not going to last long at 35 amps
.25 AR500 wear plate. 40 Amps. 25 IPM. Standard tip. Thick shim. Little to no dross… easily removed
Sorry text was cut. It’s .25
Looks good. Steel plates for shooting?
Yes. For a buddy of mine. I made one before free hand… this is oh so much better.
I know this, it’s just a sacrifice for the smaller kerf width😉
Thank you for the chart and info.
hello everyone. I am a total NEWB at CAD and CNC. I just recieved my table with the new razorweld45
and I cannot find the tip size. only mark I found was 45amp. any help?
I believe they are 1.0mm. At least for my torch - but that was a year & a bit ago (I was batch 2 of the original orders). I also got 0.6mm, 0.8mm and I thought I saw a 0.9mm available.
You need to match the power to the tip size - you’ll blow out a 0.6mm tip if you use 45A. I typically used max power (45A) so the 1mm tip. But if you’re going to do fine details on thin material you might want the 0.6mm at 25A.
thanks for that. I have an old thermodynamics plasma cutter and it shows the tip size on them but not the new razorcut. I guess I will have to run out and buy some and see if the new ones are marked.
Which torch do you have with the Razorcut?
The new X45 torch is a 1.0mm tip and from my understanding that is the only size that fits the torch which appears to be a limitation of the new torch.
I have the new x45 torch and after some research yes it is the only tip I can use for it.
.25" 40a @ 45 ipm. Barely any dross. Hypertherm tip/electrode.
Anyone have a current chart ? or 16 gauge settings for Razorweld 45 CNC and what tip works the best ? Having a lot of issues with kerf width and large holes at the ends of my cuts . I am sure it is a setting issue just trying to get it straight…
This might help:
https://docs.google.com/spreadsheets/u/0/d/12SPhiHimP9lWIOJTGaHhDAiaQoUz5Hq0YjbL92mMBSo/htmlview#
Thank You ! been testing trying to get cuts without defects . It is challenging the Fusion 360 having more information than you need makes it difficult . The biggest problem i am having is “divits” where the torch comes in and maybe stops was trying to run with no lead out. Not sure thats the answer either … The lead ins and pierce height seem to be critical . I need to control where it goes in so the the divits are located in inconspicuous places. any and all help appreciated
anyway thank you
