I downloaded several files from fireshare but having issue loading them on to mach3
I can download the files, but having issues after that
only files I could load were the break in one
and a scorpion one I found in mach3
any help would be appreciated
thanks
tony88in99
You need to import the dxf into fusion 360 then, create tool paths and then post process the cut file. At that point you would be able to load the cut file into mach 3. There are videos created by langmuir that will walk you thru everything.
thank you, I am learning how to use the software, but still a lot for me to learn
