I’ve had this machine but still cant figure out how to create a format that mach will read. Mach only keeps saying generating tool path but nothing else happens. Can someone guide me towards a site or video or something to help get cutting
Lots of possible issues here.
Did you install Fusion and Mach3 with the Langmuir profiles & plugins?
Did you toolpath and generate the TAP file in Fusion without errors?
Can Mach3 run the break-in program?
What type of PC are you using? What version of Windows? Which version of Mach3 are you running (demo or licensed full version)?
Figured it out finally,I was missing the specifications for the machine. Watched a video and installed it but now it starts cutting at a random spot. how can I get it to start at a specific spot ?
While in “Manufacture” mode in F360 and setting up your 2D profile, the last tab at the top of the profile setup window has a spot for “positions” at the bottom. This is where you can specify the entry/exit points for your cuts…
If it’s random spots on the piece of material you’re cutting out of, it’s a function of setting the origin point in your original drawing…
Best I can explain it… Maybe some of the other guys will chime in here as well…
Thank you I’ll check it out.
