Made progress today but still need some help
After working through some trouble shooting where my plasma would pierce and then lock the Mach software up, switched to a new computer and that problem has been corrected. Now the issue is it will pierce, the torch will run the path but not be cutting when moving. I’m making a simple tab with a slot in it. It will pierce, do the motion of cutting the slot and then move to the outside, Pierce and do the motions of cutting the outside and then stop. It runs the complete program but only ever cuts on the pierce task.
Is the issue with my G Code now? Any trouble shooting tips for this?
Do you have the torch in 2T mode?
If you have the torch hooked up and Mach 3 loaded will it fire if you turn it on with the F5 key and stay on until you turn it off?
It’s in 2T mode and no it will fire and turn itself off after a couple seconds.
I guess I should mention…I pressed the torch fire button in Mach, not F5 if it makes a difference.
2T is right. Since it fires at all it means you have the wiring correct. Is it a Razorweld 30? I think there was an issue with the torch not firing correctly due to a capacitor that needs to be removed.
Here’s a link to that post:
Is the air light in the plasma unit’s front panel? Do you have a dehydrator attached to the air?
It’s a 45. I’ve got a few inline filters before the air hits the plasma cutter.
Hmmm…running out of ideas here :slightly_smiling_face: Did you try new consumables? I know the ones you have are new but some folks have seen new ones fix their issues.
Ground hooked up to work piece?
I did not. I have some that I can try, I guess I just assumed that if it’s cutting the pierce portion of the program it should be cutting the lines too regardless of consumable conditions. I’ll give it a shot. Langmuir sent me a new plasma cutter to try as well as a new break out board but I didn’t want them to waste inventory on me if my cutter and table are operating correctly and the issue is software based. I was excited to see the torch move today and Mach not freeze after the new computer was hooked up.
The computer I’m now using is old and probably near its last leg. It’s running Windows 7 currently and just meets the specs required by Mach. Think a newer computer would help any?
Yes. The ground is hooked directly to the work piece.
Maybe. But it seems it’s good enough to get Mach loaded and running and actually start. If you were getting part way through I’d ask about Demo vs licensed but you should be at about line 10 or 15 when you say it’s dying on you.
Is the arc actually getting established or are you only getting the pilot arc? Do you see it cut through the metal? If not, then the cutter is killing the arc because you’re not establishing a plasma arc and cutting thru. You should see sparks shooting out the bottom of the piece or the water getting all roiled up under the material if you’ve got the water table. What’s your pierce delay setting?
Can you upload your TAP file (the G-Code file) so I can grab a quick look?
The arc seems to be fine. It penetrates the material and leaves a hole in both pierce locations. I’d have to double check my delay settings. I mimicked what the instructional video stated.
The G Code is as follows:
(brake tab)
N10 G90
N15 G70
(2D Profile1)
N20 G0 X1.6016 Y0.619
N25 M3
N30 G4 P0.5
N35 G3 X1.6616 Y0.559 I0.06 J0. F100.
N40 G1 X2.625
N45 G3 Y0.891 I0. J0.166
N50 G1 X0.6252
N55 G1 X0.625
N60 G3 X0.459 Y0.7249 I0. J-0.166
N65 G3 X0.6252 Y0.559 I0.166 J0.0001
N70 G1 X1.6616
N75 M5
N80 G0 X1.7216 Y0.0375
N85 M3
N90 G4 P0.5
N95 G3 X1.6616 Y0.0975 I-0.06 J0. F100.
N100 G1 X0.125
N105 G2 X0.0975 Y0.125 I0. J0.0275
N110 G1 Y0.825
N115 G2 X0.425 Y1.1525 I0.3275 J0.
N120 G1 X2.825
N125 G2 X3.1525 Y0.825 I0. J-0.3275
N130 G1 Y0.125
N135 G2 X3.125 Y0.0975 I-0.0275 J0.
N140 G1 X1.6616
N145 M5
N150 M30
I appreciate the help man!
Have you tried running a different program by chance?
I don’t see anything in that code that should turn off the torch before it finishes the cut. It’s pretty standard code. @langmuir-daniel probably needs to verify that the Crossfire is going to handle it but I can’t see any odd code there. He should see this post since I tagged him.
The delay is a half second. That’s what this line does:
N90 G4 P0.5
You can bump it to 1.0 to see if that helps. For thin materials (down to 14ga) I haven’t had any issues with mine but maybe you need a bit more time to fully pierce and recognize the arc is established.
I have not. This was the first and only one that I did. Ive been working with Mike and I’ll touch base with him at some point today. I just feel bad bugging these guys for what is something that’s probably a silly mistake on my end.
Thanks man. I’ll finally have some solid time to sit down with the system again tomorrow night. I’ll play with the delay then. Thanks everyone!
Not silly. It comes with the territory :slightly_smiling_face: Once you get it working you’ll be fine.
