SheetCam is a replacement for Fusion 360’s tool path generation. You will still need Mach3 to run the programs. And you can still use Fusion 360 to design parts.
I stand corrected Mike_C (I should have known that).
Curious if this was ever resolved and if so what worked for you.
I literally got cross threaded
Check the rest of the info I gathered, here http://forum.langmuirsystems.com/t/rounded-corners-on-squares/2940
I started using SheetCam and all has been peaches since then.
Actually, no more issues since adjusting the acceleration in Mach3 to 180.
