I designed and printed this water shield for the Z-axis on my Crossfire Pro. It is designed to be a tight slip fit over the bottom of the Z-axis assembly and should not need any fasteners to hold it in place. I made it to fit around my machine torch that is mounted on a machine torch mount that I designed, so your torch may not be in the exact same location. I haven’t cut anything with it on the machine, so I don’t know how well it works at deflecting the water or holding up to the heat from cutting.
I posted the STL file at Thingiverse here : Langmuir Crossfire Pro Z-axis water shield by starrcycles - Thingiverse
