I am a dog and Erik is a baby. I sure hate to see you take your grandchild to the first day of school if you can’t tell the difference! ![]()
And what Erik said about tabs is correct. It would only put it on the outside contour.
I’m not going to tell my little boy you think he looks like Jim’s dog. ![]()
ROFL. You guys are a riot duo.
Yum! Sounds good!
I suppose I should look that reference up before I comment right?..It isn’t a real beverage…is that right?
It is so confusing. ![]()
it works! Exactly as I intended, nice and tight against the machine. Only adds 2.5" of width and 11" depth on that side. There will be a diode laser enclosure right behind it to the right of the CFP. This touch screen will control both.
I did find one design flaw. I designed it to clear the transmission, which it does but sort of forgot about the keyboard. Building a complete, integrated model would have identified this problem earlier. I downloaded a 3D model of the keyboard, but did not build out the complete machine. I’d have to find a model of the CFP.
So, on build1, I’ll drill new holes higher on the mount plate to accommodate the needed 0.5". I’ll fix the model.
I uploaded everything to Fire Share.
https://www.langmuirsystems.com/fireshare/apple-keyboard-mouse-tray-for-cfp-v2-razorweld-cut-45-11ga
