I purchase the THC upgrade for my Gen1 so it was pretty much just swapping out the electronics box to easy. Before doing so my x and y axis worked fine no issues. After I got everthing installed i jogged the Z and X axis with no issies but the Y just buzzed. My system doesnt get used as much as some of you may do so I thought maybe with the humidity we have the motor corroded and froze so I purchased a new servo motor. After replacing the motor it still just buzzes. I thought maybe it was spinning on the threads so I took it off so I could verify if it is spinning and it is not spinning just buzzes.
Thanks @TinWhisperer for a little insight. After reseating some connections I went back over my wiring and found the culprit. I bought some new connectors that required me to rewire them. Looks like I crossed the green and red wire… Swapped them out and back in business.
