Did i order wrong cable
That looks like a hypertherm CPC cable. Does it not fit on the back of your machine?
@Angryfab Welcome to The Forum
Is the plasma cutter the CNC model with the machine torch? If not then there is no place to plug the cable into.
The large end goes into the plasma, the port is on the back. Unless its not there because you didn’t buy a model with the CPC port. You can buy the kit from Hypertherm. But I thought all the packages that ship with a machine torch have it.
I figured it out tks. Now im having a problem with thex axis not wanting to travel at high speed . it turnes blue an makes a noise when going from hole to hole then my part comes out wrong .
