Has anyone replace their XR control box, only to have the table not power on with the new box?
Have you checked the power supply inside is set to 120v inside instead of 240v. Its a switch on the side of the internal power supply.
Or is the screen grayed out?
Thanks for the tip!! It did need to be switched. But the issue turned out to be that my emergency stop switch was pushed in. Back up and running now!
