I had a similar issue and it turned out to pe a very small cut line.
I didn’t see it till I supper zoomed into the drawing.
also, it looks like you are cutting too slow and too hot too much dross/slag on the back side.
I have very little if any when I cat material under 1/8" unless it Stainless Steel
Thank you guys for your help. I tightened my Z axis up, adjusted my cutting speed, and redid my drawing and it ended up coming out as it should.
so I guess we can mark this as solved?..
