Hi. I’m using the latest version of Fire Control 20.6. I noticed that the visualizer units do not appear to be accurate anymore. As well, when I use the ‘set program origin’ option, it doesn’t encompass the entire part, as in the attached photo. Anybody else having this issue. I can work around it but it’s a nuisance.
That issue has been discussed on the Facebook group and I believe Langmuir is aware of it. It seems to only happen on curved parts when you rotate and have to set the program origin.
Yes I have the same issues when needing to nest or make bigger parts. This does not work and it has also made gantry want to go the opposite directions. Hopefully they can get it fixed.
