com.jogamp.opengl.GLException: Method “glDeleteBuffers” not available
at jogamp.opengl.gl4.GL4bcImpl.glDeleteBuffers(GL4bcImpl.java:10246)
at com.langmuir.cnc.desktop.visualizer.VisualizerCanvas.lambda$clear$5(VisualizerCanvas.java:806)
at com.langmuir.cnc.desktop.visualizer.VisualizerCanvas.display(VisualizerCanvas.java:337)
at jogamp.opengl.GLDrawableHelper.displayImpl(GLDrawableHelper.java:692)
at jogamp.opengl.GLDrawableHelper.display(GLDrawableHelper.java:674)
at com.jogamp.opengl.awt.GLJPanel$Updater.display(GLJPanel.java:1446)
at com.jogamp.opengl.awt.GLJPanel$10.run(GLJPanel.java:1521)
at jogamp.opengl.GLDrawableHelper.invokeGLImpl(GLDrawableHelper.java:1293)
at jogamp.opengl.GLDrawableHelper.invokeGL(GLDrawableHelper.java:1147)
at com.jogamp.opengl.awt.GLJPanel$OffscreenBackend.doPaintComponent(GLJPanel.java:2095)
at com.jogamp.opengl.awt.GLJPanel.paintComponent(GLJPanel.java:569)
at java.desktop/javax.swing.JComponent.paint(Unknown Source)
at java.desktop/javax.swing.JComponent.paintChildren(Unknown Source)
at java.desktop/sun.swing.JLightweightFrame$3.paint(Unknown Source)
at java.desktop/javax.swing.JComponent.paintToOffscreen(Unknown Source)
at java.desktop/javax.swing.RepaintManager.paint(Unknown Source)
at java.desktop/javax.swing.JComponent._paintImmediately(Unknown Source)
at java.desktop/javax.swing.JComponent.paintImmediately(Unknown Source)
at com.jogamp.opengl.awt.GLJPanel$12.run(GLJPanel.java:1535)
at java.desktop/java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.EventQueue$4.run(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.desktop/java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.run(Unknown Source)
Visualization not working. Here is the error report! HELP!
Can you post your G code?
What Version of openGL are you running? Can you provide more details about your computer? Feel free to provide these to support@langmuirsystems.com
I’m getting the same error!
Damned thing was working fine. Then the next day I got the same error.
I’ve attached screenshots of my pc system info from fireControl alert box.
See photos
Here’s the other:
Any help would be much appreciated.
Thanks
James
I purchased a new laptop for under $500 and it solved the issues. The problem was in the OpenGl…
[Visualization not working. Here is the error report! HELP!] RESOLVED
Update your video card drivers and if that doesn’t work, install a later model video card with the latest edition of openGL support.
I had an old Nividia Gforce 7 card, installed it and updated the drivers. fixed it.
Hope this works for all.
Thanks.
James Ruther - https:/potmetal.repair
