Up loading projects to Mach3
This is how far I get it starts moves the start cutting point fires torch and does nothing else. Help would be great thanks
Where was that code generated? I can’t see the whole program, but it looks like you have a G4 command with no duration command. In other words, it will sit there paused forever until you press cycle start again.
Additionally M3 and M5 commands are used for torch on/off. Did M7 work?
I hit cycle start serval times it still didn’t do anything else and every project I put in does the same thing it Rapids over to the Pierce point fires a torch that see it
And yes M7 did work the torch did fired
