when I import a drawing I show two work tables on my screen one red and one gray, and when I run tool path it always starts off the gray table, I can’t get back to one table. what am i doing wrong or what setting do I have wrong.
The gray one is the size of your work area(table cutting limits) and the red is the size of your material. The gray one is set in Machine Options and the red one is set in Job Options.
The red one is so you can put in the size of the piece of metal you are using and make sure your cuts fit on it. I just set them both to the size of the table at 48 x 33 for the Pro. It’s not important for anything other than making sure you can fit your parts on a piece of metal.
thank you I got the tables together
