Here are these pieces finished and assembled from the video above.
Quarter inch aluminum. I ended up cutting the components out of flat bar instead of sheet so it’s 6061 instead of 4043. My partner welded and assembled it.
Nice job guys! Your partner has a very steady hand!
Thanks, I can weld but not like him. I am more normal skilled level welder.
Here’s some closer pics.
That is masterful welding.
I wanted to ask a question of how the notch (circled below) played a part of this project. Is the tube smaller in diameter on that end?
good spot. there was going to be two different sizes. 1.5" sch 40 and 2" sch 40 but it ended up being all 2" so both patterns were the same.
Another stream at 7:30am pst .
We are going to make a cut file for a couple 1/4" aluminum gussets and a bumped form 1/8" sheet metal visor for a canopy rack.
Here is all the client information I have to work with.
Lets make some code !
I’ll log into the discord server too.
Added during live stream.
Thank you!
Here’s a follow-up on the headache rack for a Toyota canopy.
Customer is happy and ready to take it on some lightweight adventures.
I was going to say “Great rack” but that sounds a bit sexist! But I have to say what is in my heart to be true: Great rack!!
My partners at the gallery want some more summer shapes.
Quail and fox Garden stakes.
I am going to put together a a nest with fusion 360 to cut later this week.
I’ll also hop on the discord server.
Watch along if you like. Starting a 545am pst
Finishing this quail family
not done yet. only had a small window to do this this morning and Fusion wasn’t happy with albatross sketch i am making in fusion. I’ll try again later today.
Update. it did load through about a minute after i stopped the stream.
I like the grass and the background grass. Great instructional video again.
And your ability to roll with the punches is unique: “And it lost all of that, Awesome!” I might be paraphrasing.
Moral of that story: After you have spent considerable time, SAVE!
I am going to try a bit of a different format today.
Less instructional, more freeform , Closer view of Fusion.
Muted mic no narration just some copyright free back ground music .
Menus wont show in windowed mode.
A background that is easier on the eyes.
Reworking this collapsible camp stove.
going to make a tea and start in a few minutes
730 ish am pst…
I am going to try a bit of a different format again today.
Reworking this collapsible camp stove some more.
Starting a 5 am April 17
Twitch Muted some of my copyright free music for “Audio for portions of this video has been muted as it appears to contain copyrighted content owned or controlled by a third party.”
you can the sections that were muted in red along the timeline at the bottom.
Copywrite zealots are not always right. I know someone who does a lot of posting on YouTube that gets tagged all the time for using copywrite music. The things is: he is using music from the Baroque era and takes the actual midi notes and puts it through his own computer to generate the sound. He records that and then attaches to his videos. He seems to have a good legal understanding of it.
He states that the musical composition is public domain so it does not fall under the law and the “performance” is done by his computer and that is not covered under the copywrite laws. When he points that out, they have no out but to remove their claim that he violated copywrite laws. He states that no matter where a performance is done, there are a lot of individuals just itching to make claims of wrong doing so they pull the trigger often without any evidence.
YouTube however has another out. They will demonetize or remove videos their algorithm determines infringes copyrights. You can object and present your case and they will remove the sanction. However, they will also remove your channel if they decide you object too much even if you prevail in your objections. Apparently they don’t like people making them do work to validate their algorithms. Classic Catch-22.
Interesting!
The individual I speak of would not be concerned about any demonetizing since his videos are basically videos for group members of his church organization. He is not really trying for any wider reach.
A quick video going over some of the section process and how the selection acts different depending on how you use it .
Thanks for doing this! I had no idea there were so many selection options available in those drop-down menus. Being able to turn off or select only bodies ect. is awesome!
