Hello we just got out table assembled and running without the Plasma Cutter. Now the Razor 45 has arrived. We are having trouble with the instructions. It seems to contradict itself. Is this unit plug and play or do I have to open up the Plasma Cutter to do some internal wiring?
If you ordered it through Langmuir, then it’s plug and play. If you acquired it somewhere else, you’ll probably have to open it up and wire it to the torch switch wires and to the torch lead and work clamp if you have the THC.
Thanks Bill and yes we ordered it through Langmuir.
I had the same question during my recent installation. They could add a statement like “skip to step xx if you purchased your razor cut through Langmuir. “
