This is my second post first one I couldn’t get it to run I have it running now or almost create G code in sheet cam when starting cycle torch goes through following the G code but it will not fire it will fire if I Press F5 read all post I could find on torch not firing everything matches the screenshots so I’m thinking I’m just doing something wrong
As usual any help will be greatly appreciated thank you
Tom
Just figured out what I’m doing wrong it’s not crossfire or Mach3 it’s the way I’m using
sheetcam To create Gcodes I have to figure out what I’m doing wrong
