Weird issue when cutting! The torch stops around the same X axis position every time in the same area. This has happened on different programs/designs. Always in the same section. I highlighted a picture that shows the issue and attached it. It’s the same section, about 2 1/2 inches across the Y axis. If I cut a piece that is further to the other side of the bed, it is fine. I don’t think it is the ground. I have it attached directly to the material. I even moved the computer to make sure there is no interference. Anyone have any ideas?
