Torch Not Firing - Troubleshooting Guide (MACH3 LEGACY)
Torch Not Firing – Troubleshooting Guide
1.) Confirm that Mach3 Settings are correct:
a.) At the top bar click Config > Ports and Pins and then click the tab for Output Signals. Your screen should look identical to the screenshot below with Output #1 checked green and Port# = 3 and Pin Number = 4. No other outputs should be enabled. If your configuration is different, make the correct changes and click apply and then OK.
b.) Go back into Config > Ports and Pins and select the tab ‘Spindle Setup’. Your settings should be identical to the screen below with the box for ‘Disable Spindle Relays’ unchecked and Output #1 entered for both Clockwise and CCW directions. If your configuration is different, make the correct changes and click apply and then OK.
c.) Go into Config > General Config and confirm that all of your settings are identical to the ones shown below. If they are not make the correct changes and click OK.
d.) If your settings are correct, turn your plasma cutter on and place the torch into the CrossFire torch mount. Be sure that nothing is below the torch and you are over air between two slats. In Mach3 there is a button ‘Torch On/OFF F5’ which is a toggle button to manually fire the torch. Click this button once and you should see your torch pilot arc come on. You should also see the ‘Torch On/OFF F5’ button blinking yellow. If your torch fires and the pilot arc goes out, be sure to press ‘Torch On/OFF F5’ again so that the light stops blinking and the plasma cutter stops flowing air. If your torch is still not firing, proceed to step 2.
2.) Check Plasma Cutter Wiring:
a.) We are going to check that splicing into the plasma cutter wiring was done correctly. Unplug the black barrel connector for torch firing from the electronics enclosure. Make sure your torch is in the torch mount and is over air between two slats and turn your plasma cutter on. We are going to simulate the relay firing the plasma torch by jumping the two leads on the barrel connector. To do this, we recommend using a paperclip and placing on end inside the barrel connector and touching the other end to the outside of the barrel connector. If torch wiring was done correctly, this will cause the plasma cutter to fire when the connection is jumped across the barrel connector. If your torch is still not firing, proceed to step 3.
3.) Check Relay and Breakout Board:
a.) With all cables unplugged from the electronics enclosure, remove the front panel by unscrewing the 10 sheet metal screws from the top and bottom of the front panel. Plug the USB cable into the enclosure and open Mach3. You should see an LED (either red or green) on the Langmuir Systems electronics board and it should be blinking when USB is plugged into the computer. Press the blinking Reset button in Mach3 and the board LED should go from blinking to solid to indicate that it is connected.
b.) For the next steps you will need to have access to a multi-meter for checking continuity and voltage. Switch your multi-meter to measure voltage in the 5V range. With the black probe on the DCM connector and the red probe on the 24V connector you should be measuring between 4-5V (be sure USB is plugged in and Mach3 is on). If you are not getting the correct voltage, then you will need to have the Main Wiring Harness replaced.
c.) Next, place the red probe on 24V and the black probe on Out4. You should be measuring 0V. Make sure that your Torch Firing Cable is not plugged into the enclosure. In Mach3, click the ‘Torch On/OFF F5’ button and the light should be blinking yellow. Go back to the enclosure and place the red probe on 24V and the black probe on Out4. You should be measuring between 4-5V. If you are not getting the correct voltage, you will need the Langmuir Systems Break-out board replaced. Be sure to click the ‘Torch On/OFF F5’ button again before plugging your torch back in to disarm the manual torch firing (button should not be blinking).
d.) Inspect the blade connectors (orange and purple wires) in the clear plastic sheathing and make sure that they are plugged in correctly. Also inspect the backside of the torch inlet port and be sure that the connections are soldered on securely.
e.) With your multi-meter in continuity mode, place one probe on the outside of the female barrel connector and one probe on the pin inside the barrel connector at the Torch On/Off Port. In Mach3, click the ‘Torch On/OFF F5’. You should have continuity between these two pins when the yellow Torch light is blinking in Mach3. If you don’t have continuity, you will need your Main Wiring Harness replaced due to a faulty relay. Be sure to click the ‘Torch On/OFF F5’ button again before plugging your torch back in to disarm the manual torch firing (button should not be blinking).
f.) Next we are going to check for continuity through the torch inlet female barrel connector on the electronics enclosure. Unplug the orange and purple blade connectors from the main wiring harness. With your multi-meter in continuity mode, place one probe on the orange blade connector and touch the other probe to either the outside barrel or the inside pin. You should have continuity to one of these. Next, probe the purple blade connector and probe the barrel connector again (if the orange had continuity to the inside pin, then probe the outside of the barrel connector and vice versa). If you are not getting continuity through both of these blade connectors to the port, you will need to have your inlet port replaced.
If you need to replace faulty items, please contact us at Support | Langmuir Systems and we will get you taken care of!
Torch stopped firing. It cut one letter then after move to next letter would not fire. Now it will not fire at all. Air comes on but no arc. Same thing if i try manual cutting. Any suggestions?
Do I even need to say its a Razorweld 45?
I had the same problem but I will say that the guys at Razor Weld were super easy to work with. I have to say way more helpful than Langmuir. I did lots of testing and blew through a lot of consumables. If you have problems with your Vipercut 45 just send them a message. I did all mine on Facebook. They are lost on a few of the things as they are waiting to get there own table to test on but what I found is there is almost a sweet spot for how tight the cap needs to be. You can have it too tight and too loose. Then I also used a zip tie to hold the torch to the rail so it does not move and loosen the cap.
I was having issues like this (although using a Thermal Dynamics Cutmaster 42) and after a lot of testing and mixed results it actually was the USB cable. Slightly wiggling the cable would start or stop the torch, ended up replacing the USB cable with a Belkin and haven’t had an issue since.
Mine ended up being a mechanical issue as it was running the movement of the torch with the nozzle staying stationary in the clamp would loosen it just enough for it to either disconnect or get some interference. So I used pliers and torqued it way tighter than I would normally and have had no more trouble.
mine is doing the same thang starts to cut then stop but air blowing out the torch what did you do to fix the problem
Sorry for the late response I was out of town. I switched to my old plasma cutter. Plan on getting a new one this year probably a hyp 45 or larger.
It was the metal I used 26 ga to thin and bows up and hits the torch. I went to
16ga and working fine
It’s nice when it’s a simple fix
ya they didn’t send a stupid guide with my machine lol
I fought that tonight. Finally said effit and dropped the 1/8" in plate on the table and ran it. Went great (just slowed the feed rate in Mach 3 & goosed the power).
Ya they didny give how to and not to in the manual
1 pin too far to the left
Sorry about that! Not sure how that passed the torch fire test we do here, but I’ll let the crew know to tighten up their process.
Ok. Now when do I get my code for the Mach 3 license I ordered yesterday? #5614
Thanks for the troubleshooting process. My new system is running inn all respects except for firing the torch. Cut45. Mine is the new version with two Aux. connectors where the blank is located in the front panel of older models. It has one 4 pin and one 2 pin connector. My manual is for the older model and does not address the existence of these connectors.
The tech at Jasic was told by Langmuir to use pin 1 and 2 on the 4 pin connector. Their system is up and running.
Via the trouble shooting process above the only problem I see is 3.6 vdc between pins 24vdc and Out4. When torch button is toggled.
Other than that the machine runs code just fine. just need the torch on.
I hope someone can help.
Best ,
Russ…
Hi,
Pins 3 and 4 on the 4 pin connector fire the torch. NOT pin 1 and 2.
Thanks Daniel.
Im on it. Let you know.
Whooo, Hoooo! Fire in the hole!
Did the job. Pin 3 and 4. Ill pass on the guidance.
Now the fun starts.
Let you know how the first cuts look.
Russ…
