Hey all,
Probably gonna be a basic fix but trying to do the first cut on my table. Got an RW45 from Langmuir.
If I do Manual Torch fire it only starts shooting air and that’s it. I have the ground clamp attached to the metal, also tried it attached to the slats.
In THC the live voltage shows 0V and if I go to cut it fails for not detecting voltage. I have the port from plasma hooked to div input, then div output to the table. Also none of the THC things light (active, ok, up, or down)
If I swap the ports on the RW45 I see 261V in the live voltage feed, try to fire and I get no air and no fire.
Any ideas? I tried searching but any similar topic was just a dead end.
