Torch distance from Z axis?
I’m looking to make a machine torch mount, and I’m curious how far the torch center should roughly be from the Z axis carriage? (Yes I’ve searched for this information, and yes I could go mount the hand torch and measure, but it’s still in the box, and I have a ptm-60 from George begging to be installed instead.) Thanks is advance.
I used 42.5mm when I designed my 3d printed mount. Machine torch mount for Langmuir Crossfire w/Z axis by starrcycles - Thingiverse
Thank you. You essentially made what I’m looking to build. Looks good! What’s the c/c spacing on the bolts that mount that to the carriage?
c/c spacing on the two 1/4-20 bolts is 50.8mm or 2".
