So I’m trying to design a basic part to cut, after watching the videos on how to design and post process everything I can’t help but think I’m missing something or not doing something right. I have added screen shots to help figure out what I’m doing wrong. I apologize if this has already been discussed.
Think of kerf width like a saw blade. So if your saw blade has teeth that are 1/8" (.125) thick it will produce a Slot in the wood as it cuts 1/8" wide. Kerf width in plasma is the same but instead of cutting with a saw blade you are using a torch/flame. Just like the saw blade that flame controls the kerf width.
you can not control kerf width, with software.
The razor weld has a kerf width of approximately .055, you can measure the size of the slot after you cut and verify this but .055 should be very close
