What do I have set wrong in my setup to cause this (green areas)? Never had this problem before. Tried decreasing radius and still getting these green circular cutting patterns on all outside radius cuts when i simulate?
I don’t know the tool you’re using, but evidently the ‘kerf’ or ‘tool diameter’ is set WAY too high.
Everlast 50s. 1.1mm kerf, 25.4mm nozzle diamter.
Found my issue, somehow post processor file location changed on my setup? Maybe using Fusion 360 across multiple PC’s is not a good idea? Thanks for quick reply TowWS!
