Titanium 45Amp with hand torch AND machine torch
Titanium 45amp power supply (240v/120v) for Sale
-45amp rated hand torch with Consumables
-125amp rated plasmadyne machine torch with Consumables
-240v stock power cable, 50 ft extension cable (optional)
-Ground clamp
-Langmuir THC/firecontrol wiring included (installed)
I have been using this machine on my Langmuir pro table for less than a year, decided to upgrade everything and no longer need this unit. In the pictures you’ll notice power cable is not installed, I have two cable options available depending on what you want but the stock cable will come with unit. The machine torch came from plasmadyne and is a 125amp rated torch and is brand new. I bypassed the internal regulator and have been running external (not included) to increase pressure for the machine torch.
The machine will cut 1/2 inch steel and sever up to an inch (advertised). I have been using it to cut 1/4 and 1/8 plating.
