Titanium 45 Cut Chart
I flipped through this manual a couple times for the titanium 45.
They sure made it vague.
Titanium 45 manual
This is pretty much all the manual has on it.
It gives you an upper guideline so we can start there and start extrapolating backwards.
So it basically gives us the cutting chart for
5/8 mild steel.
45 amps, 15 in per minute, 110 PSI, torch height 1/16, this is its maximum rated setting
The spec chart also kind of gives us most of our minimum settings too.
?(thinner then 5/8") Mild sheet
15 amps, ?(faster then 15ipm) inches per minute, 80 psi, torch height 1/16th. This is its minimum setting.
Now we have two goal posts.
Everything else interpolated between these goal posts are likely proportional to these minimum and maximum figures.
I’m sure there’s many people out there that have been writing down their settings they could share and slowly start filling in the blanks between these goal posts.
