Question do I need to use the THC for 1/4 to 1/2 inch thick steel. And if not how can I turn it off in sheetcam.
I don’t know of any reason not to use it. If you want to turn it off, you can do that by turning it off in Firecontrol when you run the program.
Don’t try to add commands to turn off the THC in Sheetcam. That is sure to cause problems.
Thanks for the info
