I’m curious to hear from those who purchased the stainless water table after having used the aluminum one. Do you notice a big difference in the table’s condition after heavy use? Thinking about buying or making one if the benefit is significant.
Thanks
The problem with the original aluminum water table, galvanic corrosion was an issue when folks used rust inhibitor (makes the water electrolytic, essentially forming a galvanic battery which corrodes the aluminum). To combat this we supplied all of the aluminum water tables with zinc sacrificial anodes but it never proved to be that effective. This is why we made the switch to stainless. You wont have any problems with the stainless.
would you provide discount to Aluminum water table owners ? i read once you guys were sending out free replacement ?
