New to this wonderful world but need some help. I have the Crossfire Pro with a Razor 45 torch. I have noticed when I cut with lead in and out turned off that the torch head is still firing when lifting at the end of a tool path. This is blowing out the single lines and small shapes. What setting have I screwed up or where do I fix this at. I currently use Fusion 360 for the CAD/CAM. Thanks for any help
Welcome,
Most likely you have the plasma cutter set in 4T .
That was the issue, I appreciate the heads up
What do you mean at in 4t please advise in having the save issue, dis-regard, I figured it out.
Thanks,
On the cutter itself. Looking at the face of the cutter press the first red arrow until the light is lit on the top II mark.
